AutoCAD Plant 3D General
Member
info
Message 1 of 2 (210 Views)
Error with Repott Creator
210 Views, 1 Replies
03-21-2013 07:10 AM
Dear all,
I have a problem with report Creator after installing Hotfix "AutoCAD_Plant3D_2013_SP1_Data_Integrity_Hotfix_64bit"  Please let me know what should i do?
The error message i receive:
Type: System.IO.FileLoadException
Message: Could not load file or assembly 'PnPDataObjects, Version=1.0.4770.40802, Culture=neutral, PublicKeyToken=null' or one of its dependencies. Failed to grant minimum permission requests. (Exception from HRESULT: 0x80131417)
Stack trace:
   at Autodesk.ProcessPower.ReportCreatorUtils.Database.PlantDatabase..ctor(String databaseFileName, ICollection`1 databaseFilesToAttach, StandardType stdType, SignInFunc siFunc, PlantProject plantPrj)
   at Autodesk.ProcessPower.ReportCreatorUtils.Project.PlantProject..ctor(String xmlProjectFile, SignInFunc siFunc)
   at Autodesk.ProcessPower.ReportCreator.Manager.SetCurrentProject(String projectFile)
   at Autodesk.ProcessPower.ReportCreator.MainForm.OnProjectComboBox_SelectionChangeCommitted(Object sender, EventArgs e)
Inner exception:
Type: System.Security.Policy.PolicyException
Message: Required permissions cannot be acquired.
Stack trace:
   at System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Boolean checkExecutionPermission)
   at System.Security.SecurityManager.ResolveCasPolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Int32& securitySpecialFlags, Boolean checkExecutionPermission)
with best regards,
Andrei
dave.wolfe
Message 2 of 2 (190 Views)
Re: Error with Repott Creator
03-21-2013 01:47 PM in reply to: info
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
