AutoCAD Plant 3D Forum
Equipment Nozzle Modification
10 REPLIES 10
Message 1 of 11
vannmannen
882 Views, 10 Replies
This topic has been seen elsewere but without any solution.
I can create an equipment, but when I click on the 'edit nozzle' pen, nothing happens.
The command line shows:
Command:
Specify point location or [Base point/Undo/eXit]: *Cancel*
Command: _.PlantNozzleEdit
Command:
And this is the same output that comes on the Plant 3D - Equipment video on youtube, but I do not get the nozzle menu.
In addition no menu comes up when I use the 'modify equipment' button.
The command line gives me this:
Select Equipment to modify:
Invalid selection. Only one equipment item can be selected
So I am stuck with a pump that only has standard size/rating on the nozzle.
Please help me !!!
10 REPLIES 10
Message 2 of 11
dave.wolfe
in reply to: vannmannen
Try changing the visual style.  I've had it happen a couple times, and switching the visual style got it working.  I haven't tried it, but regenall may work too.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 3 of 11
vannmannen
in reply to: dave.wolfe
Thank you Dave.
I have tried all the visual styles but none of these give any improvement.
Neither did the regenall command 😞
Message 4 of 11
dave.wolfe
Can you post the dwg?
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 5 of 11
vannmannen
Of course I can.
This is the centrifugal pump with in standard configuration.
Tnx.
Message 6 of 11
vannmannen
...thats made in 2012 version
Message 7 of 11
hwood818
Did this issue ever get resolved?  I am having the exact same problem!
Message 8 of 11
vannmannen
in reply to: hwood818
Sent from my iPhone
Message 9 of 11
vannmannen
Yes, the problem is solved.
First of all my brand new laptop had some severe bios issues. We ran a check on it and had to reset the whole thing. The program was slow and this bios thing might have been the reason for the nozzle issue. In addition I re-installed/repaired the program and now it works just fine. In your case, I would try the re-installation and see if this helps.
Message 10 of 11
Rich.O.3d
i was having the same issue, an update to the graphics driver fixed it
the last nvidia tesla driver was a bit flakey, the newest one solved a few issues.
ps i find REGEN3 works better than regenall (its specific for regenrating solids I think)
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Message 11 of 11
hwood818
A co-worker of mine actually discovered that the reason my pump was breaking is because if you plug in a motor diameter that is too big (the radius of the motor exceeds the dimension from the top of base to center of motor) it breaks the pump into 5 pieces and it cannot be revised from that point on.  You just have to undo until it is no longer broken.  In our case because the dimensions were correct, we ended up making the pump with 3d solids and then converting it to an intelligent piece of equipment.
”Boost
