AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Equip Nozzle Tags
5 REPLIES 5
breckanderson
408 Views, 5 Replies
Equip Nozzle Tags
I have a new equipment with a boot. Nozzles are comprised of both equip generated and attached plant entities. That have nozzles. I want the nozzle numbers to match my purchase drawing. I can't figure out how to modify the nozzle numbers to have alphas (6A-6B) or number them to skip a number so assigning them with attached component nozzles can be done.
5 REPLIES 5
I have Same Proplem I can't Edit the Nozzle No. For Example  i have Nozzle (N6) i want Change To (N6B)
any one can help Us please
Ahmed Helal
Press CTRL when clicking the nozzle, then you get a pencil symbol, which lets you edit the nozzle.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
That does not allow you to change the nozzle number. You can only change the location and type. I have learned that I need to set up a custom equipment tag in the project set up. See Jason video listed below.
I recorded a video with some info about configuring the nozzle tags for Plant 3D:
Try this
I did the exact same and get the result (I think) you're expecting.
Send me a PM with your email and we can take it from there.
Tomislav Golubovic
Autodesk, Inc.
”Boost
