AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Elevation display in Navisworks
8 REPLIES 8
Message 1 of 9
Arun_Kumar_K
836 Views, 8 Replies
Presently I don't find a option in Navsiworks to display the Pipe elevation modelled in Plant3d. Request Plant3d team to take up with Navisworks team, to provide the feature in Navisworks. It would be nice to get the feature like startx,starty,starz and endx,endy,endz from Autocad Plant3d.
If there is any way available to bring in Navisworks now, please let me know.
8 REPLIES 8
Message 2 of 9
Arun_Kumar_K
in reply to: Arun_Kumar_K
Looking for reply from users and autodesk.
Message 3 of 9
Arun_Kumar_K
Why there is no reply from Autodesk for the query raised??
What should I take?
Will this feature will be added in Navisworks? or
The question raised is not relevant for Plant3d.
Request Autodesk team to respond to the query if the post is not replied by any other users.
Message 4 of 9
My suggestion would be to click on "Windows" in the ribbon (under the View tab), then select "Measure Tools" and it will open a new dialog, so when you click on the measure command, it will tell you the X, Y and Z of the item/s
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
Message 5 of 9
Arun_Kumar_K
In measure tool, how to ensure it picks the centre line of pipe?
Message 6 of 9
Arun_Kumar_K
Awaiting for reply for the above post.
Message 7 of 9
Arun_Kumar_K
Taken up the above issue in Navisworks forum also,no reply. I find the co-ordinaries of startx, startY, startZ and endX,endY,endZ are not displaying in the properties of intelligent pipes in plant3d.As these are not available in the properties of plant 3d, Navisworks doesn't show the same.
Kindly take up with development and resolve this issue. Awaiting for reply from Autodesk.
Message 8 of 9
Arun_Kumar_K
Keeping quiet from Autodesk team is not a healthy for discussion forum.
Message 9 of 9
Arun_Kumar_K
No confirmation yet...will I get the feature requested?,,, yes or No....I need a straight answer
”Boost
