AutoCAD Plant 3D Forum
Editing BOM in Plant3D Isometrics
15 REPLIES 15
Message 1 of 16
Eshleman78
3369 Views, 15 Replies
How do I change the text color in the BOM in my Plant3D 2012 Isometric setup?  It is currently 0,255,255.  I've tried changing the Table Style text color and nothing changes.
15 REPLIES 15
Message 2 of 16
Edit the cell, unlock it and change the color in the Properties
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 3 of 16
Eshleman78
in reply to: Eshleman78
Thanks for the reply, I just found the solution in an older post also.
Message 4 of 16
dustyray2010
Use a crossing window to select all cells, then go to properties, and select color. You will have to do this on every iso.
I haven't been able to change color in iso setup without losing the formula req'd.
Dusty
Message 5 of 16
Hi, isn't there an easier way to change this in the iso set up for not having to do it in every drawing ?
also when I plot the drawing I can control all the colors with the plot style table but not the BOM txt, even with monochrome it stays with 0,255,255
Message 6 of 16
dave.wolfe
in reply to: alvaro.nimasco
Edit the table style in the bom isometric setup and change the data text color to by layer.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 7 of 16
neonade
in reply to: dave.wolfe
Please show step by step on how to change the font color on the data cells, I am having quite difficulty in doing this.
Thanks.
Message 8 of 16
neonade
in reply to: neonade
I think I all got it messed up when changing the text color by layer by selecting the words and changing it on the text editor which is not right as shown below.
What I have found out correct way is to select the entire cell row then unlocked it, then change the color on the properties (Ctrl+1), on the Content area, change the text color 🙂 and it works,
Message 9 of 16
dpreezm
Hi Dave,
I know this post is veeeeery old, but busy with setups in P3D 2013 and cannot get my "color" template to print in B&W?
I have tried everything!
Please help!
-=StevieWonder=-
"Trust me, I'm a draftsman"
Message 10 of 16
Stefan_WSP
Hi!
You can solve the problem by unlocking the cells, Mark the cells and click on cell_locking and tick in unlocked:
Like this.
After that right click and click on properties and change text color to e.g white like this:
After this you once again tick in the Content and Format locked in the ribbon / Cell Locking icon.
Then click Return to Project Setup and click Save changes to "iso.dwt" when that message comes up
Hope it helps
/Stefan
Message 11 of 16
trs-iea
in reply to: Stefan_WSP
I did this and now none of my materials some out it just shows default.
Message 12 of 16
dpreezm
in reply to: trs-iea
Hi trs-iea
I also had this problem, to fix it is simple, just re-define your BOM table and then change the color settings as explained, then lock all cells again and save the template. It worked for me.
Cheers,
-=StevieWonder=-
Message 13 of 16
concadman
I know this is an old thread but this has got me frustrated.
Using P3D 2017, I simply cannot unlock the cell to change the font color?
Command tableedit can get me into the headings and title but not the data cells?
I am comfortable with tables and editing them in AutoCAD no problems, except this one, I simply cannot unlock the data cells!
Are they permanently locked and controlled through project manager now?
Message 14 of 16
concadman
in reply to: concadman
Ok, found the details":
Go to Project setup
Isometric DWG Settings
Title Block and Display
Setup Title Block
Click on BoM Table
Click on Gray area around table at top left
Right click grey square
Locking -> Unlocked
Properties -> Text Color change to prefered colour
Save changes....
I was stumped on the red step. This has been left out in so many forum postings to the frustration of users.
Message 15 of 16
Ruffy85
Congrats!
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Message 16 of 16
concadman
My problems weren't over then. Once I locked the cells again they no longer fill out when generating an Iso, so I left them unlocked and it worked.
”Boost
