AutoCAD Plant 3D General
Valued Mentor
JohnHolder
Message 1 of 8 (447 Views)
ERROR with Catalog builder - METRIC.....
447 Views, 7 Replies
09-19-2012 12:34 PM
trying to create a parametric catalog for PVCu ( that is useable )
created the parts
cap / reduction tee / flange / pipe / concentric reducer / coupling / 90 ell / 45 ell / tee / flush bushing ( issues )
After this is all done, entering in all the values in excel.  I build the catalog... then spec editor uses *funny* math and decidecs to change most of the work I just did. *edit yes in excel the size is mm not inch*
eg 16mm pipe is now 400 inch pipe.
25mm pipe is 25 inch pipe
140mm pipe is 140 inch pipe
160mm pipe is 4000 inch pipe. etc etc.
While I have Edit catalog in imperial the numbers show up properly ( with only a few with mm tagged properly )
I change it to edit catalog in metric - then most of the numbers get all wanked up. ( not all )
serously wtf?
also when I exported the catalog into excel ( pre tuning it ) some of the values are in mm some are not.
So I went through each and every size and added mm after it.... when it was rebuilt it dropped most of the mm and swap them to inches. - which of course did NOTHING. - spec editor just decided again to change everything.
any way to fix this bug? or do I have to waste more hours RE-EDITING the entire catalog.  - on top of everything, I had all the fittings modeled up and converted.... but spec editor decided it did not want to find the parts - even though everything was linked properly in the correct directories... almost two days wasted so far..
Also I am having major issues trying to parametric model a flush bushing.  Anyone have success in this?
it always falls down to cannot create it with the geometry selected.
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Valued Mentor
JohnHolder
Message 2 of 8 (442 Views)
Re: Issues with Catalog builder - METRIC.....
09-19-2012 12:58 PM in reply to: JohnHolder
Update....
In the spec editor, I update the all the pipe sizes to the correct size,
when I save to catalog, spec editor decides to change them - just a couple mind you.
16mm pipe becomes 400 mm pipe
160mm pipe becomes 4000 mm pipe.
the Nominal diameter changes on both.
and of course, on a few of the pipes they show up all messed up aswell.... 20 ( 0.75mm ) - it's bloody 20mm pipe.. not 0.75
5 of 18 pipe sizes show up like that.
Master Yoda.
Employee
TomislavGolubovic
Message 3 of 8 (423 Views)
09-19-2012 05:48 PM in reply to: JohnHolder
That seems odd, it looks like a Imperial to Metric conversion that its doing.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Valued Mentor
JohnHolder
Message 4 of 8 (419 Views)
Re: ERROR with Catalog builder - METRIC.....
09-19-2012 06:47 PM in reply to: JohnHolder
I can email the catalog / spec / excel sheet - to see if there are any errors?
John
Master Yoda.
berucheva
Message 5 of 8 (404 Views)
09-20-2012 12:54 AM in reply to: JohnHolder
Hi JohnHolder!
I have the same problem ((
Valued Mentor
JohnHolder
Message 6 of 8 (364 Views)
09-21-2012 09:44 AM in reply to: JohnHolder
This still needs to be addressed.
Master Yoda.
Valued Mentor
JohnHolder
Message 7 of 8 (341 Views)
09-24-2012 12:46 PM in reply to: JohnHolder
Opening a ticket.
Master Yoda.
Valued Mentor
JohnHolder
Message 8 of 8 (321 Views)
09-26-2012 09:24 AM in reply to: JohnHolder
Resolved.
Had to delete my excel sheet,
rebuild from the pipe spec ( not catalog )
once again edited all "In" / "Inch" to "mm"
rebuilt catalog from excel
repopulated spec from catalog
it worked this time.
Master Yoda.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
