Thanks for the reply, but I find this catalog manager very annoying to handle.
Let’s say you want to create a new catalog only with this flanges EN 1091-1, you need to start with an existing catalog (Metric or Inches) that is fill with other pipe fittings that you don’t need in this catalog.
Then you spend a lot of time deleting those fittings that you don’t want in this catalog, and because this is SQL database (I think it is) it takes a long time to delete this items, for example try to delete all the bolts from this catalog and see how much time it takes to delete them.
But, let’s say that after delete all the unused pipe fittings, I want to add to this catalog some pipe how you do this? If you don’t have nothing in this catalog to make a copy.
I understand that this spec/catalog editor is designed to restrict the user to make catalog database mistakes. But Autodesk should find another approach to catalog creation.
I my opinion the user should be able to start with an empty catalog where he selects the type that he wants to work with, inches or metric like in the project creation wizard.
After creating this catalog it should appear one menu where he can select what to insert in the catalog, for example insert one WN flange, since each type of fitting have is different properties is should exist one for each different item, after inserting the item it should be able to edit and modify the Common Properties for this inserted item, also the ability to copy the Item should be available, and some way to group the Type/Class items.
I think this way will be much easy to manager and edit new catalogs.
It just my 2 cents
Abilio Ramos
