I'm trying to create a dummy leg as shown on attached sketch. I can't get any of the catalog supports to center on the pipe - they all default to match bottom of pipe. Does anyone know how to force the support to match center of pipe?
Solved by jabowabo. Go to Solution.
No I don't. Thats a little unusual; virtually every dummy leg standard I've seen maintains common BOP to match the supporting steel. May I ask what the design purpose of this configuration is?
Just as an FYI for anyone else interested: I solved this problem by creating a dummy leg via a Python script and it works as shown on the attachment above.
#CREATED by Jason Hudson Ver 1
#EMAIL: wjasonhudson@gmail.com
import aqa.math
import math
from varmain.primitiv import *
from varmain.var_basic import *
from varmain.custom import *
@activate(Group="Support", TooltipShort="Dummy Leg Support", TooltipLong="Dummy Leg Support", LengthUnit="in", Ports=1)
@group("MainDimensions")
@param(D=LENGTH, TooltipShort="Pipe diameter", TooltipLong="Pipe diameter")
@param(DLegDia=LENGTH, TooltipShort="Dummy Leg diameter", TooltipLong="Dummy Leg diameter")
@param(DLegLen=LENGTH, TooltipShort="Dummy Leg length", TooltipLong="Dummy Leg length", Ask4Dist=True)
@group(Name="meaningless enum")
@enum(1, "align X")
@enum(2, "align Y")
@enum(3, "align Z")
# (testacpscript "DLEG_DSF")
# testscript1
def DLEG_DSF(s, D=4.5, DLegDia=3.5, DLegLen=48.0, **kw):
#Calculation:
PLen = 24
#Create pipe
p = CYLINDER(s, R=(D/2.0), H=PLen, O=0.0).translate((0, 0, -(PLen/2)))
p.rotateX(90)
#Create DLeg
dl = CYLINDER(s, R=(DLegDia/2.0), H=DLegLen, O=0.0).rotateY(90)
dl.subtractFrom(p)
p.erase()
#Connection Points
s.setPoint((0, 0, 0), (0, 1, 0))
s.setLinearDimension('DLegLen', (0, 0, 0), (DLegLen, 0, 0))
