AutoCAD Plant 3D General
jabowabo
Message 1 of 4 (277 Views)
DummyLeg for Horizontal Turn
277 Views, 3 Replies
09-25-2013 07:54 AM
I'm trying to create a dummy leg as shown on attached sketch.  I can't get any of the catalog supports to center on the pipe - they all default to match bottom of pipe. Does anyone know how to force the support to match center of pipe?
dgorsman
Message 2 of 4 (263 Views)
Re: DummyLeg for Horizontal Turn
09-25-2013 09:51 AM in reply to: jabowabo
No I don't.  Thats a little unusual; virtually every dummy leg standard I've seen maintains common BOP to match the supporting steel.  May I ask what the design purpose of this configuration is?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
jabowabo
Message 3 of 4 (220 Views)
09-30-2013 06:22 PM in reply to: jabowabo
I'm not familiar with the design intent except it is for insulated pipe. I was just given the spec and told to create the items. I can get a support to center but the pipe does not cope correctly where it connects...
jabowabo
Message 4 of 4 (203 Views)
10-01-2013 08:34 AM in reply to: jabowabo
Just as an FYI for anyone else interested:  I solved this problem by creating a dummy leg via a Python script and it works as shown on the attachment above.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
