I used to be able to put the dummy leg on the elbow's node.
But somehow now I can only put the dummy legs on the weld joint.
And sometime's I cannot even put an dummy legs on anywhere of the elbow.
It just disapear.......
I just quickly tried this in both Plant 3D 2013 & 2014. I was able to place a dummy leg at the elbow no problem. So was this working for you in your current version of Plant 3D and then stopped? Or are you saying you upgraded to a new version of Plant 3D and it stopped. Also, if you’re working with others, are other users able to do this at their workstations? Have you tried to Audit the drawing and the project? Purged the data cache? Do you have all the applicable Service Packs or Hot Fixes loaded? Up-to-date video driver? If you perhaps give more detail on the sequence of events that led up to this behavior, the community here may be able to offer more suggestions
I'm not quite sure what happened.... It just stop working in a sudden to all our station...
My current is 2013.
I audit the project, purged and we update service pack 1.
We just boght all the computer last year.
I click on dummy legs and try to put on elbow, but it didnt do automatic adjustment and disappear once I click the right key.
