Maybe this should go in the P&ID forum.
having problem copying files from a other project.
I'm trying to run "Copy drawing to project". It's P&ID's in this case.
Both projects are run separatly with out any problems, both in P3D 2014.
But when I try to "copy drawing to project" I get the "Drawing version error", see attatched file.
Both projects are set to save in autocad 2013 format, changeing and saving in an older format doesn't help.
Tried running the purge program with no luck, also not getting any errors when auditing.
Anyone have any ideas?
On the drawing that you are getting the error on, have you migrated that project to P3d 2014?
Also AutoCAD P&ID and AutoCAD Plant 3D P&ID are two different animals. I would ask my P3D P&ID questions here.
The drawings that we want to copy are created from a "pure" P3d 2014 project.
The project that we want to copy it in to is migrated from 2013 to 2014.
Although we haven't had any problems with this before.
//Mikael
