AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Drawing units are Feet = pipe units are feet, not inches
1 REPLY 1
413 Views, 1 Reply
OK,
Our company changed to AutoCAD Civil 3D a few weeks ago and all of our Plant 3D projects use the Civil 3D files as backgrounds via XREF.  I have tried to make the XREF's work well using several methods (inserting at a scale factor of 1/12, etc.) but the best way seems to be to create our drawings with units set to feet.
If I set units to feet in a new Plant 3D drawing, everything is great right up until I start routing pipe.  I picked Schedule 80 PVC just for the trial run and routed some 2" pipe, but it shows up in the model as 24" pipe (2').
Is there a setting for this or do I just need to go back to inches for drawing units and figure out some other way to bring in our XREF's so that the coordinates and elevations are accurate?
Stephan
1 REPLY 1
TomislavGolubovic
What are the Plant project units?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
”Boost
