Dear Dave,
Tried as mentioned in your site about how to set up to genereate Line No. wise report in Report creator. But I find trouble in keeping the aquisition as P3dLinegroup.tag. The window doesn't show any thing in the aquisition, please see the attached pic.
Kindly help to keep P3d Linegroup.tag in the aquisition.
Solved by Arun_Kumar_K. Go to Solution.
Solved by dave.wolfe. Go to Solution.
I can't tell, but it doesn't appear that you created the property on the Piping and Equipment class. Once you have it on that class, having a property acquire the tag from the line group should stick. Can you verify which class you added the property to?
Can you show a screen shot of your report groupings?
