AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Datamanager Cut Length Unit
3 REPLIES 3
dogyeom
814 Views, 3 Replies
Hello.
I have one question.
I made plant 3D project. (Unit is Mixed Metric)
And place pipe object in the drawing.
Next, I see pipe cut length in datamanager.
But I don't know this units.
This units is inch? or MM?
Thanks.
3 REPLIES 3
jabpascua
in reply to: dogyeom
Hi, may i know where to find the cut length in data manager?
thanks
Tags (2)
DVaquand
Hello
If your project is defined in MM, the values ​​are in MM.
To reply to @jabpascua the cut length is displayed when the "Pipe" section is selected in the data manager.
== French ==
Bonjour
Si votre projet est défini en MM, les valeurs sont en MM.
Pour répondre à @jabpascua la longueur de coupe s'affiche lorsque la section "Pipe" est sélectionnée dans le gestionnaire de données.
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
jabpascua
thank you so much sir, anyway, i wanna know if it is possible that the only pipe cuts visible in ortho cube will relflect in bom report, regarding how long is the actual pipe? i mean example, 1 have 6mtr pipe, but i want to show in my orthocube is just 1.5mtrs, and i want to see in my report that 1.5mtrs only, not the whole 6mtr.
”Boost
