I need to build a pipe spec for ductile iron Class 150LB. There is an existing one provided out of the box, but is missing most all the sizes I need. However, the DI 250LB has all the sizes I need. Would it be simple enough to just duplicate the DI 250LB and change the 250 to 150 on the general and all sizes list? Or are there other differences that I don't see right off?
Any sugggestions for this are welcome.
Solved by JohnHolder. Go to Solution.
First thing that comes to mind - are the pipe/fittings the same size dimentionally? and if they are not, how exact does your drawing need to be?
I have checked thru the different blocks and they appear to be the same size. I do not know though if 'something' in background of the program may be scaling or doing something different.
You can open the spec's in the <spec editor> and check the values to see if there are values in the background that may need to be changed.
You could just copy the spec rename it and edit the information.
