AutoCAD Plant 3D General DIscussion
tmccar
Message 1 of 5 (299 Views)
Custom part not to scale
299 Views, 4 Replies
10-12-2012 02:57 AM
I have created a custom part with PLANTPARTCONVERT and then I used PLANTCUSTOMPARTS to insert the part into a new drawing. It seems to insert at a remote distance from where the insertion point is, and is scaled down much smaller than the original part is. The ports seem to be detached from the part itself also.
      Where am I going wrong in this?
Member
Vrocha5
Message 2 of 5 (106 Views)
Re: Custom part not to scale
04-23-2014 08:57 AM in reply to: tmccar
I am having the same problem... but my parts are all scaling up. Only one part of the same family came in at the right size. As you can see it the picture, my 3" flange insert valve is not fitting in between the two flanges like the 2" valve does
tmccar
Message 3 of 5 (88 Views)
04-24-2014 02:59 AM in reply to: Vrocha5
Explode the Plant entity, and check the X, Y and Z scales of the block. They should all be 1. If not, explode the block and re-create it. Re-check that the scale is now 1, and you can proceed to PLANTPARTCONVERT it.
Distinguished Contributor
patpat79
Message 4 of 5 (67 Views)
04-28-2014 12:35 AM in reply to: tmccar
First of all, know your project units. Second, identify your drawing units. Make sure they are the same. If metric is the project unit, use milimeter, then proceed on making your 3d model part into a Block. Then Use the plantpart convert. If you follow those instruction. Your item will be on scale as you desire.
patpat79
Message 5 of 5 (66 Views)
First of all, know your project units. Second, identify tour drawing units. Make sure they are the same. If metric is the project unit, use milimeter, then proceed on making your 3d model part into a Block. Then Use the plantpart convert. If you follow those instruction. Your item will be on scale as you desire.
You are not logged in.
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
