AutoCAD Plant 3D Forum
Welcome to Autodeskā€™s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Custom Valve
8 REPLIES 8
Message 1 of 9
twdtech
651 Views, 8 Replies
Custom Valve
I am trying to create a custom valve but, as soon as I save to the catalog, the "Edit Operator Assignments" button becomes greyed out which means I cannot assign operators. I am creating the custom valve (Valvebody) from "Plant3D Parametric Graphics". Any help would be appreciated.
8 REPLIES 8
Message 2 of 9
Here are some useful references for custom parts creation in AutoCAD Plant 3D. Check out the handout PDFs especially.
(If this answers your question, please mark it as an Accepted Solution.)
Martin Stewart
AEC Support Specialist
Message 3 of 9
Martin, thanks for your reply. I had a look at the relevant PDF's but, could not see anything which could disable the "Edit Operator Assignments" Button.
Message 4 of 9
Thanks Vwry Much Martin
it;s really useful Reference3
Ahmed Helal
Message 5 of 9
Look at several of the out of the box (OOTB) valves. Notice how some allow you to "Edit Valve Operator" and others don't (check valves for example). It's not universal. This command is not applicable to all valves.
Martin Stewart
Message 6 of 9
Hi Martin,
The custom valve I have created is a Y-Pattern globe valve. I looked at the valve catalogue and all globe valves have the "Edit Operator Assignments" button enabled. Valves which do not have the button enabled are valves which do not require operators but, this is not the case with my custom valve.
Message 7 of 9
It may help if you review the materials from AU and go through the custom valve creation process again, starting with an existing valve that works and modify from there.
Martin Stewart
Message 8 of 9
Martin,
There is no existing Y-Pattern valve in the catalogue to use as a basis for creating a new valve. Where would I find the materials from AU?
Message 9 of 9
See my first response for some AU links. Also, to get a better response from the discussion group here, you could outline that steps you took in detail.
Martin Stewart
ā€Boost
