AutoCAD Plant 3D General
New Member
joachim.oelschlagel
Message 1 of 7 (628 Views)
Custom Stub-in to elbows
628 Views, 6 Replies
01-24-2013 12:03 AM
I have tried to make stub-ins in elbows for long thermo wells since 2011 release, and it seems like it's still not possible in 2013 release. Someone knows of a workaround to this?
Snip below illustrates where i would like to make the stub in: (Note that it's not connected in my example)
dave.wolfe
Message 2 of 7 (615 Views)
Re: Custom Stub-in to elbows
01-24-2013 06:46 AM in reply to: joachim.oelschlagel
Click the + grip off the corner of the elbow, hit S for Size and enter the size you want.   THe insertion options are somewhat limited, but you can use the connectionoffset option to move it up our down on the elbow.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
New Member
liuyong816
Message 3 of 7 (591 Views)
01-24-2013 05:29 PM in reply to: dave.wolfe
Hi dave:
     I want to show the connection offset value on the iso to reduce the counculation work from the connection coordination, is there any possible way to config?
     Thanks a lot !
Active Contributor
Layout-Bob
Message 4 of 7 (561 Views)
01-27-2013 11:17 PM in reply to: joachim.oelschlagel
Thanks Dave,
I managed to get it right on a horizontal pipe that turns upwards. Then I tried on a horisontal bend (which did not work), and then I tried to continue on the first pipe run (see attached picture).
In both cases I use your method with "connectionoffseT" and I use distance: -((Bend radius)/2)
Slightly confused :smileyfrustrated:
Active Contributor
Layout-Bob
Message 5 of 7 (552 Views)
01-28-2013 01:22 AM in reply to: Layout-Bob
Hmm.
Seems like the original post were posted from my suscription-center login which is my real name.
Regards
Joachim
dave.wolfe
Message 6 of 7 (543 Views)
01-28-2013 07:10 AM in reply to: Layout-Bob
Yea, it doesn't seem like there are enough options on the offset.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
New Member
kaisakol
Message 7 of 7 (396 Views)
05-27-2013 05:43 PM in reply to: Layout-Bob
Thank you.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
