Is anyone aware of a way to bring a custom property created in your Catalog Editor (even Spec Editor) to be brought across to your model?
I came across this article:
http://blogs.rand.com/architectural/2012/10/custom-catalog-properties-for-plant-3d.html
However I cannot seem to get the values I have created to come across from the Spec Editor to the Plant 3D piping Model.
Example, I wanted to create a custom property in Spec/Catalog Editor called PipeID, which will show values of the ID of piping components.
I imagine this requires some sort of XML editing to get this "mapping" right?
Any pointers would be appreciated.
Thanks.
Solved by Peter_Jansoone. Go to Solution.
If you create properties with the same name (100 % exactly !!) in catalog, spec and project, the information wil flow through.
If it doesn't work, try a name wthout characters 'ID' in it, that might trigger special actions.
Hi Peter
Thanks, your second suggestion seemed to work.
I tried changing ID to "LinerDiameter" and it seemed to bring the values across. As you mentioned, "ID" may have another trigger associated to it.
Thanks very much
