AutoCAD Plant 3D General
Proccie
Message 1 of 3 (221 Views)
Custom Property from Catalog Editor to 3D Model
221 Views, 2 Replies
09-29-2013 11:22 PM
Is anyone aware of a way to bring a custom property created in your Catalog Editor (even Spec Editor) to be brought across to your model?
I came across this article:
http://blogs.rand.com/architectural/2012/10/custom-catalog-properties-for-plant-3d.html
However I cannot seem to get the values I have created to come across from the Spec Editor to the Plant 3D piping Model.
Example, I wanted to create a custom property in Spec/Catalog Editor called PipeID, which will show values of the ID of piping components.
I imagine this requires some sort of XML editing to get this "mapping" right?
Any pointers would be appreciated.
Thanks.
Valued Contributor
peter.jansoone
Message 2 of 3 (190 Views)
Re: Custom Property from Catalog Editor to 3D Model
10-01-2013 12:43 AM in reply to: Proccie
If you create properties with the same name (100 % exactly !!) in catalog, spec and project, the information wil flow through.
If it doesn't work, try a name wthout characters 'ID' in it, that might trigger special actions.
Peter Jansoone
Plant Design software consultant at Greenock CAD service
Proccie
Message 3 of 3 (185 Views)
10-01-2013 01:11 AM in reply to: peter.jansoone
Hi Peter
Thanks, your second suggestion seemed to work.
I tried changing ID to "LinerDiameter" and it seemed to bring the values across. As you mentioned, "ID" may have another trigger associated to it.
Thanks very much
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
