AutoCAD Plant 3D General
Active Contributor
PLANToftheAPES
Message 1 of 5 (354 Views)
Custom Parts from Custom Geometry Works on My Machine but Not Others
354 Views, 4 Replies
10-27-2011 12:01 PM
I created expansion joints in our custom parts drawing, then added them to our catalog under Catalog Editor, Create New Component, and Use Custom Geometry.I changed components and then came back to the expansion joints and I get the png pics for each expansion joint meaning it's good and was added to the catalog. Then I added this to a spec. I was able to succesfully place it on my machine, however, others can not place it on their machine. On their machines it shows as a white blank square next to the Expansion Joint on the Part Insertion palette, and when they click on it to place it, they get an error message "Can't find symbol for specified part".
Our custom parts catalog is called Custom Parts Catalog and is located on our server under "Project"\AutoCAD Plant 3D 2012 Content\CPak ASME along with a folder named Custom Parts Catalog. Under the Custom Parts Catalog folder are 2 folders called 200 and DWG. Under the DWG folder is our custom parts drawing.
Why would it work on my machine but not others?
Active Contributor
PLANToftheAPES
Message 2 of 5 (347 Views)
Re: Custom Parts from Custom Geometry Works on My Machine but Not Others
10-27-2011 05:08 PM in reply to: PLANToftheAPES
We solved it. We found that on every machine, in the spec editor, under Tools, all machines must point their Shared Content Directory to the same place on the server. This resolved the problem. We thought that pointing the shared content directory was only for using catalogs in the spec editor, but it also affects Plant 3D as well.
Employee
Message 3 of 5 (339 Views)
10-28-2011 11:32 AM in reply to: PLANToftheAPES
Mr. Apes,
Your custom parts are probably block based. For parametric parts, all you need is access to the spec.
(Love the handle, by the way)
Peter Quinn
Senior Product Manager
Active Contributor
PLANToftheAPES
Message 4 of 5 (333 Views)
10-28-2011 01:16 PM in reply to: PeterQuinn
Thanks Peter. And thanks for your help last month at Ask the Expert.
Mr. Apes.
Active Member
Message 5 of 5 (218 Views)
Error unable to find ASMm218res.​dll file at Spec Editor
10-05-2012 06:42 AM in reply to: PLANToftheAPES
Hi everyone ,
I have a problem  , but a little bit different.
I am using spec editor. And I'm gonna add custom part at catalog builder . Consists of a problem at this time.
"Unable to find  tr-TR\asmm218res.dll "  error.
Autocad don't find tr-TR\asmm218res.dll , so am I.
I can't find tr-TR folder in Program Files.
Where should I'll find tr-TR folder ?
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
