AutoCAD Plant 3D Forum
Custom Part Problems
3 REPLIES 3
maxdc
793 Views, 3 Replies
Since the 2012 version is almost here. I re-installed the autocad Plant 2011 demo version to suggest it to my superiors. Currently we do not use programs of this kind.
One of the things that I should demonstrate is that we will be able to use our blocks library.
To do this I decided to create a metric Project and create a custom part
The steps that I followed are:
  • Inserted the block
  • Convert the block using the plantpartconverter command
  • Created the Custom Part using the plantcustompart command
  • Completed the settings
  • Inserted the custom part
 The problem that I have is that I can not connect any other element to the custom part created
See pictures attached.
I followed the steps suggested on the help and I do not find what I am doing wrong.
Could you help?
Thank you in advance.
Max
3 REPLIES 3
ybogdanov
in reply to: maxdc
In the window of t'he first picture change mm to inch, and end type to PL. And then use t'he same spec (cs150).
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
maxdc
in reply to: maxdc
It worked. Thanks
Max
BGUNARATHNA
in reply to: maxdc
I have a same issue and I did what you mention here. but how can I change type of spec when I import custom block.
”Boost
