I am working with a project and looking for a solution to create a walk through video from the plant 3D files, could you please advise if the software has a build in function to create video?
thank you!
Solved by Arun_Kumar_K. Go to Solution.
When I open file in Navisworks I only see 2d reference lines?
How do you operate interface for a walk through in Plant 3D?
Thank you,
You will need to install the Plant 3D object enabler for your version of Navisworks.
