AutoCAD Plant 3D Forum
Creating walk through video from plant 3D file
3 REPLIES 3
chargingcharging
975 Views, 3 Replies
I am working with a project and looking for a solution to create a walk through video from the plant 3D files, could you please advise if the software has a build in function to create video?
thank you!
3 REPLIES 3
You can do from Navisworks.
mgalicki
in reply to: Arun_Kumar_K
When I open file in Navisworks I only see 2d reference lines?
How do you operate interface for a walk through in Plant 3D?
Thank you,
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
darrelldixon
in reply to: mgalicki
You will need to install the Plant 3D object enabler for your version of Navisworks.
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-autocad-pla...
”Boost
