AutoCAD Plant 3D Forum
Creating new instruments which are categorized as "instruments" in the specs.
10 REPLIES 10
Message 1 of 11
mario.brecher
4560 Views, 10 Replies
Hello to everybody!
first of all, i'm sorry for my worse english. 🙂
i have a problem in Plant 3D 2013.
how can i create a instrument which:
- is categorized in the spec as a "instrument" ("in-line-instrument")
- can get a tag-number
- listed and numberized on the isometrics as an instrument and the TAG is shown to with that bubble.
i got everything running except that it is categorized as an instrument in the specs and project.
but it must be possible. taking an instrument from "C:\AutoCAD Plant 3D 2013 Content\CPak Common\CustomParts Metric Catalog.pcat" is categorized correctly.
thank you very much for your help!
greetings from austria
Mario
10 REPLIES 10
Message 2 of 11
Hi Mario,
So from the catalog via spec and the P3D project you have to do the following steps:
  • In the catalog you have created your valve. Important properties here are ValveAlignemnt: Inline, ValveDetail: e.g. Check, ValvebodyType: e.g. Check, Iso Symbol Type: VALVE, Iso Symbol SKEY: e.g. CKFL.
  • After you have created this component you have to add it into your spec. Either in a spec of your content folder (so this spec will be used for every new project) or directly to a spec of your project.
  • Start Plant 3D and open your project and open the project configuration.
  • Switch to the node 'Plant 3D DWG settings - Plant 3D Class Definitions - Piping and Equipment - Pipe Run Component - Instrument - Inline Instrument
  • Note for this class there is already a tag format available, called 'Instrumentation Tag'. You can add here different tags format, too.
  • Now the preparation for the isometric: Switch in the project configuration to 'Isometric DWG Settings - Title Block and Display' and click 'Edit Isometric Symbols...'. Select a similary block in the dialog, make some changes to the block and use 'Save as...'. In this example let us call the block 'Checktest'. Save all and close project configuration
  • Open the IsoSkeyAcadBlockMap.xml with an xml-editor like XML Notepad which is free. It is located here: <project folder>\isometrics
  • Add a new row here: <SkeyMap SKEY="CKFL" AcadBlock="Checktest"/> and save the file
  • For showing the tag of the instrument in the isometric look for the two snapshots which I have attached here. The one thing is inside of your project configuration, the other thing is to edit your isoconfig.xml of your used iso style. If you use XML Notepad for the xml editor it looks like the one attached snapshot. To find this position go to the node 'Themes - Theme (Default) - Annotations - AnnotationSchemes'.
Let me know if I could help you
Regards
Bernd
Re
Bernd G.
Senior Product Support Specialist
Message 3 of 11
Hi Bernd!
thank you very much for your fast reply.
and sorry again for the worse description.
i have everything running. except the category in the specs.
when i add it to a spec it is categorized as an valve and not as an insrument. see the screenshot "messung als armatur.jpg"
but when i add a instrument from the default catalog "CustomParts Metric Catalog.pcat" which is in the "common" folder, the instrument is listet as an "in-line-instrument" in the specs. see the screenshot "messung als instrument"
i think the category would be defined in the "Basic Part Family Information" Part on "add new Component".
see "neues bauteil.JPG"
Kurz in deutsch:
Hallo Bernd! Danke für deine Beschreibung. iso symbol, iso liste, tags und alles passt. nur finde ich beim armaturen anlegen nichts für instrumente und ich glauch dass es die kategory ist, die ich auswählen muss, dass es dann in der rohrklasse eine messung ist und keine armatur.
danke nochmal für deine hilfe.
Grüße Mario
Message 4 of 11
Hi Mario,
Currently it is only possible to create directly an inline instrument in the catalog via scripting. It is currently not possible to do this directly in the spec editor or in the catalog builder (except the option with scripting). It is already logged as an enhancement to our development department. So I would recommend to create a valve here. For the íso symbol type use INSTRUMENT and for the Iso SKEY you can choose your own SKEY. Be aware that this custom SKEY has to be published in the ISOSKEYACADBLOCKMAP.xml with the associated block of the project configuration - isometric symbols.
On German:
Hallo Mario,
Leider ist es zur Zeit nur möglich mit Scripting ein Inline Instrument direkt im Katalog zu erstellen. Es geht weder über "Neue Komponente" im Katalog Editor noch über den Catalog Builder (Ausnahme: Scripting). Dies haben wir schon als Verbesserungsvorschlag bei der Entwicklung geloggt. Deswegen empfehle ich Dir eine Armatur hier zu erzeugen. Für den Iso Symbol Type nimmst Du INSTRUMENT und für SKEY einen SKEY Deiner Wahl. Gib allerdings darauf acht, dass dieser SKEY dann in der ISOSKEYACADBLOCKMAP.xml bekannt gemacht wird und mit einem Block verbunden wird, der mit einem Block aus der Projektkonfiguration - Isometrische Symbole übereinstimmt.
Viele Grüße
Bernd
Bernd G.
Message 5 of 11
thank you Bernd!
so i think i'll stay on the "valve" category. i mapped everything in the ISOSKEYACADBLOCKMAP.xml and allready made new ones.
thank you very much again, for your help!
Message 6 of 11
Hallo,
gibt es mittlerweile eine Lösung hierfür?
Das Intrumente auch als Instrument im Katalog erstellt werden können.
Als Benutzerdefiniertes Teil geht es ja, nur im Katalog nicht
Mfg
Mark
Message 7 of 11
Hallo Mark! soweit ich weiß nicht. wird vlt. in der nächsten version kommen.
Grüße Mario
Message 8 of 11
Hello Mark and Mario,
unfortunately there are no news here. It is the same behavior as before.
Regards
Bernd
Bernd G.
Message 9 of 11
Thanks Bernd for the Info!
Message 10 of 11
We have problems with mapping general instruments symbols. As far as we can see there is no direct way to map a general instrument.
Because there is no mapping between P&ID and 3D model there is no way to validate if the same instruments are on the same location in P&ID drawing and 3D model.
The proposed work-around is that we define P&ID symbol as an inline instrument.
But our instrumentation is connected directly to our equipment so there is no line.
The question is how can we connect inline instruments (or valves) in P&ID and 3D model directly to equipment.
Janko
Message 11 of 11
M-JGP
in reply to: mario.brecher
Hi
1- Create a new catalog only with the instrument
2- Create an excel file with "Export to Catalog Builder"
3- Edit the excel file and show all the columns, look for the "PartCategory" column and change all the values to "Instruments", look for the "PnPClassName" column, and change all the values to "InlineInstrument", save the file.
4- In the Spec Editor, under Tools use Launch Catalog Builder and Build Catalog, select the new excel file.
5- Add the new families to the Catalog desired and use it in the Spec.
Sorry for my English
”Boost
