AutoCAD Plant 3D Forum
Create ortho sections other than North/South/West or East directions
2 REPLIES 2
edgeplant3d
567 Views, 2 Replies
I just want to know if there is a way of creating ortho section views in say NE or NW, SW or SE direction.
EG
2 REPLIES 2
JohnHolder
in reply to: edgeplant3d
Rotate the model 45 deg is the only way I think.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
JarrodMudford
in reply to: JohnHolder
The work flow I have used here on many cases is to set up some "dummy" models and xref the models you require. Then rotate the entire set of objects to where you want it. This file is not to be used for design, nothing would connect to the ports at all.
Then when running your Ortho, use the "Dummy" model.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
”Boost
