AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Create new Component Category
4 REPLIES 4
jiri.zubek
1105 Views, 4 Replies
Can I create new Component Category like "Fittings" in Spec Editor?
4 REPLIES 4
Venkatesan.A
in reply to: jiri.zubek
Sorry but you cant they are hard coded.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
dinant
in reply to: Venkatesan.A
Is this still not possible or are there any changes in the meanwhile?
I would like to add instrumentation to the catalog and have them in a seperate group than the valves...
Also on the part lists.
Dinant Weenk
jabowabo
in reply to: dinant
The workaround is to export the catalog from the Spec Editor (File/Export to Catalog Builder).  Open the Excel file and change the PnPClass and Category columns values to "Instrument".  Save the Excel file and use Catalog Builder to 'Build Catalog' and select the Excel file.  Add the results to the catalog you choose (choose duplicate if prompted - Update will not change the class).
Note:  If you are creating the components with Catalog Builder then you can skip the export from Spec Editor and change the values from the Catalog Builder Excel file.
dinant
in reply to: jabowabo
It works as described.
Only to bad it doesn't work with AutoCAD Custom blocks...
Dinant Weenk
”Boost
