I want to annotate my pipes for ex DN100-10013 (DN Pipe Size - Line Number).
but I couldn't achieve it.
Anyone can help? Thanks.
Solved by Irensaga. Go to Solution.
In this documents you will find everything you need to personalize Tags and Annotation.
http://images.dcheetahimages.com/au.autodesk.com/ama/images/media/PD208-1_Extras.pdf
Cheers,
Irene
Click Solved if this answered your question
How do you change the annotation tag list to make one the default - I have a drg with 1000 valve tags to show & want this tag to be made the default or the only tag on the list so it speeds up my work
Gary
