Hello
nice idea to install Autodesk® AutoCAD® Plant 3D 2014 Extension 2 x64 (WIN7) on friday 😞
P3D doesn't start anymore. It crashs always after 'Vorbereiten der Arbeitsumgebung - PROJECTMANAGER' when it switsches to full screen mode.
What can I do? (I don't want to reinstall P3D)
Guido
Hi Guido,
on my site Ext 2 works fine. Test the following four topics to resolve the issue here (I'm sorry but some of them has to do with re-install or similary stuff). Do the topics in this order:
Note: Make sure that you back up any customized AutoCAD Plant 3D files before implementing this procedure
Close AutoCAD Plant 3D
***Warning: Improperly editing the Windows registry could render your operating system unusable.
Running Plant 3D in daignostic mode checks if some other service/application is prevending the correct run of AutoCAD Plant 3D.
If it is now working then a different service/application is prevending the correct start of Plant 3D. You have to re-check the services/tools again till you get the wretch.
Do a repair of the installation (not a re-install) via control panel - programs and features
Look for those article to do a clean uninstall and re-install:
Please, let me know if I could help you.
Regards
Bernd
Did you manually replace any dlls with a hotfix? You'll need to put back the original DLL before installing Ext 2 if you did.
Also, did you happen to install an AutoCAD Service Pack?
Hi
yes I've installed 'AutoCAD_PNID_2014_PID_Tagging_Hotfix_64bit' some weeks ago.
It is necessary to install Ext 1 before installing Ext 2? Because I didn't...
Regards
OK
I've uninstalled P3D.
Installed it again. Reboot
Installed Ext 2. Reboot
And P3D works again.
Guido
