AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Correlation between port numbers in custom geometry.
2 REPLIES 2
Lars_Petersson
355 Views, 2 Replies
Hi all.
Can anyone tell me if there is a correlation between port number and the order in which you add ports for custom geometries using PLANTPARTCONVERT command?
Does the first created port always get number 1? Or is it controlled somehow in spec editor?
2 REPLIES 2
Correct!
The port numbers in the spec editor are the port center points what you selected after the PLANTPARTCONVERT.
So the first selected point will be the port 1, the second will be the port 2 and etc...
Attila Vallyon
Great!
Thanks Attila
”Boost
