I have a .stp file that I would like to convert to a .pcf. I can export the .stp to a .dwg then open it in Plant. Then I see a PCF Export in the Isos tab. But I can't export it. I'm guessing I'm missing something because the the Line Numbers text box is blank. I'm clueless about Plant myself. Do the pipes need to be worked on to be created as smart piping objects first before a person can convert it to a .pcf?
Solved by dgorsman. Go to Solution.
A PCF file contains enough information to draw an isometric (and in most cases, do material management as well). That includes but is not limited to connection point information (size, type, coordinates), short and long description, BOM category (fabrication, erection, etc.), new or existing, any extra component information which may have been imported into ATTRIBUTENN properties, plus global properties such as line number, linear and weight units, and so on. A basic object (STP, IGES, and other formats) has none of this information until it is assigned through piping design software.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Best Regards,
Pat Andres
GHD Manila
CAESAR, as a stress analysis program, doesn't model the way piping design does. Depending on how many components and the individual stress engineer (some of them prefer to model directly in CAESAR instead of importing objects), a simple drawing may be more efficient.
