AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Connecting pipes and fittings with minor differences in x or y
13 REPLIES 13
Message 1 of 14
GSC_HAYA
1083 Views, 13 Replies
Hello
when I use _.plantpipeadd I can draw a line between fittings with a difference of 0.0001 mm for example. (Where these differences come from I'm wondering every time)
When I try to connect two parts with the same difference using plantconnectjoint, it does not work.
So I have to delete the pipe and insert it again... 😞
What is to do?
G
Plant3D 2022 German
WIN10 Pro
13 REPLIES 13
Message 2 of 14
Arun_Kumar_K
in reply to: GSC_HAYA
I too need solution for this, even 0.5mm difference causing pipe and fitting disconnection. Where to set the tolerence?
Message 3 of 14
We are having the same issue with imperial units. The added aggravation is that when units are set to Architectural 1/16" precision, you won't see the 0.0001 difference in X or Y.
Some of our designers give up when the pipe won't connect to the fitting and tell me to fix it. Half an hour later the simple 2" elbow to pipe connection if fixed, and all that time wasted for a dimension that a pipe fitter/welder would never see.
Message 4 of 14
Arun_Kumar_K
I have been waiting for reply from Autodesk PPl, but asusual no reply.
We need more interaction from Autodesk ppl also here, if you find only users are sharing their views.
If you want to develop the software, please keep interacting here.
Message 5 of 14
dave.wolfe
in reply to: Arun_Kumar_K
You'll need to play with th joint settings in the DefaultConnectorsConfig.xml in the project folder. Each joint has an Offset and Slope tolerance.  You can play with these values and see if it clears up your issues.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 6 of 14
Arun_Kumar_K
in reply to: dave.wolfe
Tried as you mentioned, but it didn't connect.
Message 7 of 14
dave.wolfe
Is this a buttweld joint? Can you post your connectors config file?
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 14
As Dave said: Can you send us the connectors config file? Also the information what kind of joint you have used?
Regards
Bernd
Bernd G.
Senior Product Support Specialist
Message 9 of 14
i have had this issue and the only way i can get them to connect is to move one of the parts to the X or Y of the other part that is off using Point Filters.
Message 10 of 14
Arun_Kumar_K
in reply to: thebearjed
Sorry for my late reply here. Attached the requested file.
The joint connection tolerance required is for Buttweld.
I tried, but it is not getting connected.
Message 11 of 14
I have the same problem. I get an error message "Autorouting can not find any paths", though I do not want autorouting to find it. I want to connect A to B with a slope.
I tried to increase slope and offset tolerances for Buttweld i DefaultConnectorsConfig, but that didn´t help.
Best regards
//Johan
Message 12 of 14
dave.wolfe
I've spoken with the product manager, and submitted a case for this, as it seems to be a bug for everyone.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 13 of 14
feschaurich
I have the same problem. Sometimes I spend a lot of time to connect two adjacent lines with 0.001mm of difference!
For while, the only way to solve it is reroute the pipeline.
A solution for this would be great.
Best Regards
Fernando
Message 14 of 14
TRdesigner82
in reply to: feschaurich
Bringing back and old post......
I know that this was a bug in 2014. Straight from Autodesk "OffsetTolerance doesn’t seem to work currently!". We're about to migrate to 2015 and I'm wondering if this is something that they felt was important enough to fix for 2015? Anyone have enough experience with 2015 yet to know?
Autodesk: Please refer to [CaseNo:09164512.]
”Boost
