We use a lot of special pipe and we need to connect two different sizes without using a reducer. For example a DN430 to a DN400, the bore is the same, but it is reduced to take a DN400 flange.
I can make a connection in the model by right clicking and select connect Component but the Isometric is split at the join.
Any ideas?
Solved by PatrickByrne. Go to Solution.
