AutoCAD Plant 3D General DIscussion
asalcido
Message 1 of 6 (1,279 Views)
Concentric, Eccentric Reducers and Reducing Tees
1279 Views, 5 Replies
01-17-2012 09:48 AM
How do you input the data in the spec Editor 2012 to show the difference in schedule of pipe fittings.  For example, a concentric reducer 4" SCH 80 LE x SCH STD SE.
Alex Salcido
asalcido
Message 2 of 6 (1,235 Views)
Re: Concentric, Eccentric Reducers and Reducing Tees
01-24-2012 05:34 PM in reply to: asalcido
So does anyone have anything about this?
Product Support
jason.drew
Message 3 of 6 (1,219 Views)
01-25-2012 03:56 PM in reply to: asalcido
Typically you would use the "Batch Assign Long Description Styles" function of Spec Editor to configure a new format or string for the properties you would need.
I attempted to configure the long description as you mentioned above. However, I wasn't able to use the size field for the second part of the string.
I am assuming you would want something similar to this for a reducer that changes in size and schedule (as an example):
4" SCH 80 LE x 6" SCH STD SE
Would be something like:
<Nominal Diameter>" SCH <Schedule> LE x <Nominal Diameter>" SCH <Schedule> SE
So there are two property fields for size and schedule in the spec, but the long description style editor only recognized the first entry for size and schedule.
The workaround I tried was to create 4 new fields:
SIZE1
SIZE2
SCH1
SCH2
But unfortunately you cannot use custom property fields in the long descriptions.
I have submitted this issue to the development team.
Thank you,
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
asalcido
Message 4 of 6 (1,213 Views)
01-25-2012 04:51 PM in reply to: jason.drew
Thanks Jason.  Just wanted to make sure I wasn't missing something.
dry
Active Member
dry
Message 5 of 6 (447 Views)
10-01-2013 07:14 AM in reply to: asalcido
Does this issue been solved in PLANT 3D 2014?
So far I cannot find how to describe (using long description style manager) two-dimensional fittings such reducer or reducing tree. On iso drawing BOM there will be always first (larger) dimension parameters visible (i.e. wall thickness). It is very confusing.
Regards
Dominik Ryś
Employee
PeterQuinn
Message 6 of 6 (397 Views)
10-07-2013 11:10 AM in reply to: dry
Does this utility from ECAD solve the problem:
http://apps.exchange.autodesk.com/PLNT3D/en/Detail/Index?id=appstore.exchange.autodesk.com%3apdoexte...
Peter Quinn
Senior Product Manager
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
