AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Collars
2 REPLIES 2
Martin60
745 Views, 2 Replies
Collars
I am currently learning and setting up 3D Plant.
I require collars on the end of my pipes for rotating flanges.
There are collars available in the catalogs DIN Pipes and Fittings Catalog.pcat and CustomParts Metric Catalog.pcat but I cannot see how to add these objects.
I noticed that when in the spec viewer the option to add collars to the palette is disabled.
Can someone explain the correct use of these objects and how I can achieve the collars I require.
2 REPLIES 2
in reply to: Martin60
Hi Martin,
Collars are fasteners and as such cannot be placed manually. They are
automatically added to form the connection when needed and reside within a
connector entity (as a sub-entity).
There is a single joint definition named CollarLapped that adds a Collar and
a Buttweld when connecting a LAP end condition to either a BV or PL end
condition. It is superceded by StubLapped that is used in the same situation
but is found first. In Project Setup, Joint Settings, you can remove
StubLapped or change it so it is not picked up.
You can also change the situation when a Collar is used by either changing
the joint definition or creating a new one.
Hope this helps.
Jorge Lopez
"Martin60" wrote in message news:6355898@discussion.autodesk.com...
these objects.
Martin60
Thanks Jorge
Sounds good.
Will let you know if I have any problems.
”Boost
