I can't see ribbon in my Catalog builder. What should I do?
I've already tried to turn it off and on. Nothing!
When I right click on top of the window, menu "show tabs" is empty.
So I can't export my template to Exel.
Can anybody help me?
is the show panels empty also
if not are the panels ticked
also just to the right of the home tab (top left corner) is a little arrow...you panel might be minimized, if you hover over it, does it say show full ribbon
if you still dont have the ribbon, can you post a screenshot please
Show panels aren't empty and all are ticked.
When I hover over this arrow it asks me do I want to minimize ribbon. When I press it Catalog Builder just closes.
Here is a screenshot
The same was with english and german versions
Have the same problem too. When i click Show Tabs, it give me an empty list
Installing Showcase 2014 from Plant Design Suite 2014 installs .NET framework 4.5 which breaks Catalog Builder in 2013. Ribbon is gone again.
However, there's Catalog Builder from 2014, which works.
Zdenko
Thanks! Unfortunately, i still need to use .NET4.5.. Have to go with 2014.
