AutoCAD Plant 3D General
agutak
Message 1 of 9 (661 Views)
Catalog Builder problem
661 Views, 8 Replies
11-03-2012 11:28 AM
I can't see ribbon in my Catalog builder. What should I do?
I've already tried to turn it off and on. Nothing!
When I right click on top of the window, menu "show tabs" is empty.
So I can't export my template to Exel.
Can anybody help me?
Anatol D. Gutak
Valued Mentor
Rich.O.3d
Message 2 of 9 (655 Views)
Re: Catalog Builder problem
11-03-2012 05:45 PM in reply to: agutak
is the show panels empty also
if not are the panels ticked
also just to the right of the home tab (top left corner) is a little arrow...you panel might be minimized, if you hover over it, does it say show full ribbon
if you still dont have the ribbon, can you post a screenshot please
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
agutak
Message 3 of 9 (640 Views)
11-04-2012 05:29 AM in reply to: Rich.O.3d
Show panels aren't empty and all are ticked.
When I hover over this arrow it asks me do I want to minimize ribbon. When I press it Catalog Builder just closes.
The same was with english and german versions
Anatol D. Gutak
Rave.Tam
Message 4 of 9 (524 Views)
Have the same problem too. When i click Show Tabs, it giv...
01-20-2013 10:02 PM in reply to: Rich.O.3d
Have the same problem too. When i click Show Tabs, it give me an empty list
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
New Member
Audun.Opdal
Message 5 of 9 (434 Views)
04-10-2013 01:20 AM in reply to: agutak
I have the same problem.
Anyone have a solution for this.
Member
zdenko
Message 6 of 9 (360 Views)
05-10-2013 02:59 AM in reply to: agutak
It's .NET Framework 4 error. You probably have .NET framework 4.5 installed. Uninstall it and install .NET Framework 4.0. I've heard that Microsoft .NET Framework 4.5 came with betas of 2014 products. It worked for me.
Zdenko Kozar
Education and tech support manager
PRIOR inženjering d.o.o.
http://www.prior.hr
agutak
Message 7 of 9 (351 Views)
05-10-2013 04:40 AM in reply to: zdenko
In Plant 3D 2014 it's OK
Anatol D. Gutak
Member
zdenko
Message 8 of 9 (317 Views)
05-14-2013 07:31 AM in reply to: agutak
Installing Showcase 2014 from Plant Design Suite 2014 installs .NET framework 4.5 which breaks Catalog Builder in 2013. Ribbon is gone again.
However, there's Catalog Builder from 2014, which works.
Zdenko
Zdenko Kozar
http://www.prior.hr
Rave.Tam
Message 9 of 9 (285 Views)
05-15-2013 06:18 AM in reply to: zdenko
Thanks! Unfortunately, i still need to use .NET4.5.. Have to go with 2014.
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
