AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Can't draw fittings anymore with standard spec connect error
3 REPLIES 3
701 Views, 3 Replies
Today we encountered the following issue:
I route a pipe of 2" CS300 without any problems.
When I try to route a 4" CS300 line it does not show an elbow when routing. When I click at an angle it places the minimum amount of pipe.
I tried the line to pipe function. I get two connection error messages. It places two pipes and an elbow on top of it.
I tried an other project whith the same spec it works without any problems. So the spec is good.
What could cause this problem?
3 REPLIES 3
quentin.contreras
Did you make any changes to the CS300 spec that is in the Project you are working in? If you start a new Plant 3D drawing within that project, do you get the same issue?
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
in reply to: quentin.contreras
Today I figured out what caused the problem. A colleague thicked the box for acception of imperial to metric connections for a buttweld joint.
quentin.contreras
Thank you for coming back on here to let us know what was causing your issue. Great job on finding the problem! Smiley Very Happy
Quentin Contreras
”Boost
