How do I change the status of bolt sets to existing? I can change the connector to existing but only the gasket is changed to existing. The bolt set remains as new and shows up in the BOM.
Solved by jabowabo. Go to Solution.
Hold down the control key and use a crossing window to select the connector components. Change to existing in the properties.
@david.ellis: You should be able to do this through the isoconfig.xml file by changing the value found in Data/AggregatedList/RowFilter. There will be a filter assigned here. Find this filter in the Filters section of the xml, make a copy, then add an exclusion for fasteners. Once you have your filter defined change the RowFilter value to your new filter. Make a backup of your original in case you have problems.
