AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Can't change bolt set to existing
3 REPLIES 3
twdtech
654 Views, 3 Replies
How do I change the status of bolt sets to existing? I can change the connector to existing but only the gasket is changed to existing. The bolt set remains as new and shows up in the BOM.
3 REPLIES 3
jabowabo
in reply to: twdtech
Hold down the control key and use a crossing window to select the connector components.  Change to existing in the properties.
Hi there,
Is it possible to simply remove the bolt set from the Plant3D Isometric MTO?
We are wanting to produce very basic ISO's with as little information as possible.
This would simplify things greatly.
Thanks for your help.
Dave.
@david.ellis:  You should be able to do this through the isoconfig.xml file by changing the value found in Data/AggregatedList/RowFilter.  There will be a filter assigned here.  Find this filter in the Filters section of the xml, make a copy, then add an exclusion for fasteners.  Once you have your filter defined change the RowFilter value to your new filter.  Make a backup of your original in case you have problems.
”Boost
