AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Can't access network catalog from Spec editor?
1 REPLY 1
Fragels
440 Views, 1 Reply
I copied an entire project from our clients server onto our own server. Everything seams to work fine exept for the Spec editor. I can open and edit all drawings in Plant 3d from the server. But Spec editor cant access the path to the server. When I try to open a file the server can not be seen in the Spec editor explorar window. Pasting the path does not work either.
The server can be accessd from Plant 3d and fro, Windows Explorer so there is nothing wrong with the connection.
What is wrong?
1 REPLY 1
JarrodMudford
in reply to: Fragels
There has been an Admin rights issue with the Spec editor.
This hotfix resolves that issue.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21194788&linkID=14116968
If it is just not reading your Drive letter, have seen this before too, then type the full path in \\servername\share\
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
”Boost
