AutoCAD Plant 3D General
Valued Contributor
Message 1 of 11 (615 Views)
Accepted Solution
Can not connect Pipe to Xref Pipe (Stub-In)
615 Views, 10 Replies
03-07-2012 07:27 AM
Hi to Everyone, are there possibility to connect a Pipe to a Xreferenced Pipe in a Model.?
I want to say...
I got some Equipment with own pipe and tried to connect a Output to a Manifold independ of the area for example a Drain with Stub.In
I know the possibility to do with Flanges and coupling but not with Stub.In.
do you know how?!...
Thanks.!!
Employee
TomislavGolubovic
Message 2 of 11 (606 Views)
Re: Can not connect Pipe to Xref Pipe (Stub-In)
03-07-2012 09:29 AM in reply to: batone79
XREF connecting works fine between Equipment to Piping, and Piping to Piping.
Are you connecting to NODE of the XREF'd model?
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Autodesk, Inc.
Valued Contributor
Message 3 of 11 (602 Views)
03-07-2012 09:56 AM in reply to: TomislavGolubovic
thanks for your replay, but my problem is..
I got a Area A and has a Output Drain Manifold of ND1000, and this Manifold crossing  Area B, to the end, after Manifold get the end I got a Equipment that need to do a Vertical STUB-IN of ND500 on xref Manifold of Area A.
Mater Piping of Area A is Xref to see Manifold ND1000 in Master Piping Area B.
Employee
TomislavGolubovic
Message 4 of 11 (587 Views)
03-08-2012 05:36 AM in reply to: batone79
I'd run the stubin in the first model to the first fitting, then continue the xref from there?
Tomislav Golubovic
Autodesk, Inc.
Valued Contributor
milic.srdjan
Message 5 of 11 (560 Views)
03-20-2012 04:21 AM in reply to: TomislavGolubovic
I think that this is big problem. Not only for stub in, also for o-lets or tees, it seam that Plant3D does not make connection through xref files.
It like, that You must in advance plan Yours piping arrangement.
We have a lot of problems with this issue..
Just imagine , as e.g.
 We have two drawings, it is standard structure when You have Plant Revamp:
one drawing with Old Pipes,
and another drawing with New Pipe system.
Then We have some interconnecting pipes, with different diameters, and we hope that plant will add connections automatically according branch connection table for classes that We use in project...BUT WRONG
NO CONNECTION ACROSS XREF FILES
Valued Contributor
milic.srdjan
Message 6 of 11 (558 Views)
03-20-2012 04:24 AM in reply to: milic.srdjan
as P. S
look at this post
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Xref-I-do-not-understand/td-p/3042834
We have alrady this conversation
Employee
TomislavGolubovic
Message 7 of 11 (548 Views)
03-20-2012 08:27 PM in reply to: milic.srdjan
It does connect through XREF, you can connect to fittings from other Piping XREF's, and Equipment XREF's
Tomislav Golubovic
Autodesk, Inc.
Valued Contributor
Message 8 of 11 (542 Views)
03-21-2012 01:20 AM in reply to: batone79
[ It does connect through XREF, you can connect to fittings from other Piping XREF's, and Equipment XREF's ]
Yes you are right we can connect a Pipe to other xRef Pipe with fittings, flanges and in the end of the pipe with node of xref pipe, I dont know if later work good in ISOs, but
YOU CAN NOT CONNECT A PIPE TO OTHER XREF PIPE WITH A STUB-IN AT HALF OF XREF PIPE.
Undertand now Tomislav Golubovic???
thanks!
Valued Contributor
milic.srdjan
Message 9 of 11 (534 Views)
03-21-2012 03:17 AM in reply to: batone79
Ok,
Yes , it is true ...It possible to connect to fitting on xref model..
but, it is SO COMPLICATE, because you must plan your model, with fittings on right place, for connection.
It seam that, if You have team of 4 or more designer, become more , and more complicated, to work..
much easy if You do not have need for xref model.
Srdjan
p.s This discussion make another question. I put this in another, let say , new post
look link
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Question-for-o-lets/td-p/3379245.
Employee
TomislavGolubovic
Message 10 of 11 (520 Views)
03-21-2012 11:11 PM in reply to: milic.srdjan
@batone, I understand the stub-in issue, I was responding to the other poster.
Tomislav Golubovic
Autodesk, Inc.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
