AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Can Not add Line Number Tag ACADP3D 2014
2 REPLIES 2
batone79
647 Views, 2 Replies
hi,
recently I migrated a Porject from 2013 to 2014 and I Installed SP1.
Well now I draw a new 3d pipe line, after I do it select all this new pipe line and go to properties/Line Number Tag/New.
In 2013 I added Line number tag without problem and now in 2014 I can not.
In ACADP 2014 don´t start the window to fill line number tag.
So any one got the same problem?.
I can not add a new Line Number Tag to a new pipe in ACADP 2014.
2 REPLIES 2
KenFauver
in reply to: batone79
I tried what you did without issue. I'm using 2014 with SP1. Make sure that the dialog is not hidden behind another dialog or on a 2nd monitor that is no longer there.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
batone79
Hi and thanks for your replay..
The problem was solved editing "tag Format" into "Project Setup" and changing one field, specifically in my case was (Piping and Equipment / Pipe Run Component / Pipe / LineNumber) with Use "Target Objet´s Property" unchecked.
This field caused error when must start prompt up  fill window.
Now I made a new Field in  "P3d Line Group" of PipeLineNumber with adquisition of "Pipe.LineNumber" and works.
Thanks.
”Boost
