AutoCAD Plant 3D General
Active Member
axeborn
Message 1 of 5 (231 Views)
Calculation of pipework system volumes
231 Views, 4 Replies
03-07-2013 04:12 AM
Does anyone know if its possible to calculate the volume of pipework in a system in P3D?
Any plug-in or other recommended software?
thanks
Distinguished Contributor
Gabriel.N
Message 2 of 5 (217 Views)
Re: Calculation of pipework system volumes
03-07-2013 07:21 AM in reply to: axeborn
I do not know if there is another way, but I would do the following.
Just as there is a property "weight", I add a new property "volume".
Then trying to work with this information in Excel.
Active Member
axeborn
Message 3 of 5 (195 Views)
03-07-2013 11:10 PM in reply to: Gabriel.N
Thanks, that would be one way to do it.
Valued Contributor
kennethmjones
Message 4 of 5 (190 Views)
03-07-2013 11:37 PM in reply to: axeborn
Just isolate all the pipes and fittings you need and get their mass properties. they are solid models right?
Product Support
gersteb
Message 5 of 5 (119 Views)
03-13-2013 05:53 AM in reply to: kennethmjones
Hi Michael,
This is currently not possible on a straight way. I have logged here an enhancement request to our development department for you.
Currently you have the options to export the Pipes and Pipe Bends to Excel and calculate there a new field called 'Volume' which is the product of 'Cut Length' and 'Nominal Diameter'.
To use MASSPROP here you have to explode the pipes and pipe bends before. So it is not a useful option here.
Regards
Bernd
Bernd Gerstenberger
You are not logged in.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
