i started in my leisure time to create some scripts for cable Trays. i have attched the scripts, cataloge and spec.
the most is "possible" with the actual Plant 3d 2013 but not all and not beautiful 😕
i have created a script for a 3x Bend type, Tee, Reducer short and 3 type of cable trays.
the problem at the moment are:
Pipe: you can create only a cylindrical pipe and must replace/overlay it later with the correct Cable Tray
Bend: it works only in 1 direction. there is no mirror function
Reducer: i have created 2 Catalogs items. because one is for left and one for right. there is no mirror function
Tested: 2d ortho generation with Tag description.
not Tested: ISOS, Part lists (specialy for Pipe).
it would be fine if someone can have a look into this and give some new ideas....
thanks
Hermann
Hi friend,
Well done work keep foreword to Knowledge us
Great
Ahmed Helal
i Hermann,
I see you master programming applied to autocad plant 3d, so I wonder if you can help me develop a specification and custom media catalog.
I'd give you several plugins purchased for autocad plant 3d:
- Create bom plugin
- Iso configuration editor
purchased in this site "http://www.pdoteam.com/store/".
A simple change to develop a catalog of media.
If you're okay with the agreement we wrote by e-mail and I just realize.
Best regards, Jose
Give my python-based catalog a try, you can customize and create your own size tray-elements:
https://apps.autodesk.com/PLNT3D/en/Detail/Index?id=5679577637251598566&appLang=en&os=Win64
Youtube link:
