AutoCAD Plant 3D Forum
CUT Problem
5 REPLIES 5
Gabriel.N
653 Views, 5 Replies
CUT Problem
Hey,
This is something that since always happens to me.
When I'm in perspective view with a short focal length like 20mm, objects that are closer are cut of vision.
Look the attached image.
Is there any way to fix this?
Tags (3)
5 REPLIES 5
Gabriel.N
in reply to: Gabriel.N
Someone, somebody, anyone knows how to fix this?
Dan.Scales
I can't reproduce this issue.
The first thing to try is an update of your graphics driver.
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Dan
Dan Scales
KenFauver
This happens when trying to view the model in perspective while clipping is on. If you turn clipping off it will go away. This is not a Plant 3D issue. It is an AutoCAD function.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
That's been a very frustrating problem for me also, thanks for clearing that up!! 🙂
Gabriel.N
Hey,
After a few years I found the solution to this problem.
Whenever I asked someone about this problem, they thought I was talking about the 3DCLIP command. But it is not.
There is a variable called: PERSPECTIVECLIP
The default value is 5.
I thought it a good value to avoid clipping is 0.01
Look the difference between them, check annex.
Att.
Gabriel Nogueira.
”Boost
