AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Borrow License Problem
2 REPLIES 2
vannmannen
980 Views, 2 Replies
I have brought my laptop with Plant 3D - 2013 abroad and unfortunatly I FORGOT to borrow a license before I left.
Now, normally I connect to the company SERVER with VPN to get a license (atleast this works fine for Microstation) but with my Autodesk Plant 3D this does not work.
The 'FLEXnet license finder' comes up on start-up and I try to both link to the server and even browse to the license file on the server but it does not accept this and show me the classic license error message. I also try to modify the 'licpath' file without any success.
For some strange reason; Inventor 2013 license is working with the same VPN connection but I neither need or use that program.
Desperatly need some advice how to get a license as I am stuck abroad and not able to work.
2 REPLIES 2
TravisNave
in reply to: vannmannen
You need to set the FLEXLM_TIMEOUT variable to extend the length of time it takes the VPN to connect to the NLM:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7574782&linkID=9240617
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
vannmannen
GREAT. This is working.
I just love you guys on this forum !!!!!
Keep it up
”Boost
