I am using Report Creator to generate a bulk BOM for the project. The BOM reports bolts as a number of sets based on flange size and rating. How can I get it to report the bolts by diameter and length. I am using Plant3D 2014 Ext 2.
Solved by patpat79. Go to Solution.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
I don't see any reports in the Report Creator that is specific to bolts. How do I access and use the query you mentioned?
You can create your own report configuration. Review the article at the link below if you haven’t had the chance. Also notice that there is a huge PDF file there to you might be interested in (Report_Designer).
See also attached image.
(If this answers your question, please mark it as an Accepted Solution.)
Best Regards,
Pat Andres
GHD Manila
