I have created a pipe spec with cast-on flanges. The bolt set is coming in as expected, however the red-bubble is buried inside the joint connection rather than sticking out some so that I can see it and easily select it. How can I fix this so that when Plant3D makes the connection, I can see easily the boltset bubble?
Solved by PeterQuinn. Go to Solution.
Could you possibly include a screen shot that way I can see exactly what you are seeing?
Quentin Contreras
Technical Support Specialist
The bolt symbol in the 3D model?
I added in a screen shot that shows the bubble. I used the IsolateObject light-bulb to turn off the fittings to expose the bubble leader. I want that bubble to be below the fitting so that I can select it without isolating off the fitting. Yes, you will see in the attachment that I am talking about the 3D model.
Thanks for the help,
Have you made any progess in resolving the problem yet? I am still doing some looking as to if there is a feature that will allow you to change the size, but have not come up with anything yet. I am still searching though...
Quentin Contreras
I think the nominal diameter and / or the the MatchingPipeOD properties of the BoltSet are used to determine the length to draw the set.
