AutoCAD Plant 3D General
PatrickByrne
Message 1 of 7 (1,570 Views)
Bolt Lengths and @@@
1570 Views, 6 Replies
11-14-2012 12:59 PM
This is just to confirm something.
In the catalog builder for bolts the length of the bolt is got from what is input as the Length in the “Piping Component Properties” section. When you add @@@ into the description Plant 3D inserts the bolt into the model and gets the length from the “Piping Component Properties” using a project setting to round the value up. In Plant 3D 2013 it looks up a bolt table to see if the length is available.
Is this correct as I was expecting a bigger improvement from CadWorx
Employee
Message 2 of 7 (1,502 Views)
Re: Bolt Lengths and @@@
11-16-2012 10:22 AM in reply to: PatrickByrne
Hi Patrick,
I started to reply to this yesterday based on my previous experience implementing bolt sizes but soon realized it was changed last release cycle so I asked the author of the changes for some notes about it and here is his response:
I hope I can declare that with short words…
For bolt length calculation we check the FlangeThickness values defined at flange and bolt set
If both are equal (or one is not set) and it’s no wafer component we use the bolt length defined inside bolt set
But if both are different we subtract the bolt set FlangeThickness from bolt set bolt length, add the flange FlangeThickness
Now  look for the next possible bolt ‘standard’ length (if define – if not we round up to next 10)
If we look now into 10HS01 spec we see that the DN 50 flange has as defined FlangeThickness a length of 18.0 mm
Now let us have a look now into the bolt set definition. We see that there is FlangeThickness defined with 20.00 mm and an overall length 87.0 mm
We see that the bolt set and flange FlangeThickness are different so we have to recalculate (booth used flanges are equal)
87.0 20.0 20.0 + 18.0 + 18.0 = 83.0
So we get a new calculated bolt length 83.0 mm … the next possible ‘standard’ bolt length would be 85.0
This definitions and recalculations give us the possibility for easier use of different flange sheet thickness with the same base definition PressureClass, NominalDiameter, EndType, Facing for bolt set selection – that is otherwise problematic if we connect  an orifice flange with a welded flange … the orifice flange normally has a larger flange sheet for the instrument connections but the same base definitions so we would always get the same bolt length defined in bolt set.
So we have only 1 bolt set for the base properties with 1 standard FlangeThickness we used for base length and recalculate it if necessary.
if look like for
  • DN 100:   95.0 24.024.0 + 20.0 + 20.0=   87.0  -> next possible bolt length would be   90.0
  • DN 125:   99.0 26.026.0 + 22.0 + 22.0=   91.0 -> next possible bolt length would be    95.0
  • DN 150: 112.0 28.028.0 + 22.0 + 22.0 = 100.0 -> next possible bolt length would be 100.0
I hope this short overview help to understand the different bolt length values
Jorge Lopez
Software Architect
Autodesk Plant Solutions
Valued Mentor
ybogdanov
Message 3 of 7 (1,486 Views)
11-17-2012 02:46 AM in reply to: PatrickByrne
One question, which is utility of Bolt Standard in Catalogs? In the Spec Editor: Catalogs->Edit Bolts Length Maping...
 Each catalog have diferent standard.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
PatrickByrne
Message 4 of 7 (1,364 Views)
11-26-2012 01:00 PM in reply to: lopezjo
Thank you Jorge, I am currently using Plant 3D 2012, but hopefully moving to Plant 3D 2013 soon. I see in 2013 there is a lot more to the bolts and it appears to be more intelligent. This is something to look at later.
MSpadaro
Message 5 of 7 (1,287 Views)
12-05-2012 04:11 AM in reply to: PatrickByrne
hi, the BOLT STANDARD LENGHT shlould take the available lenght form the EDIT BOLT LENGHT MAPPING function inside the catalog. But it doesn't. If i define a new BOLT MAPPING STANDARD call DIN931 and inserting the same valure (DIN931) in the BOLTCOMPATIBLESTD field of the bolt component it should take the value entered. Let's speak about M16 --> lenght 86: the result is that the system take anywasy 85 as calculated according to what you have explained. Where is really defined the STANDARD BOLT AVAILABLE LENGHT? thanks
Member
k.schachinger
Message 6 of 7 (798 Views)
05-22-2013 07:23 AM in reply to: PatrickByrne
Thanks a lot Jorge!
This helps me very much. I was been told that the calculation works in a completly different way and therefore i didn't understood why the calculation is alway wrong.
But I think such informations should be available in the online-help. This would avoid many problems beforehand!
And it's true. The Bolt compactible standard mapping is just not working. Please FIX IT!
Best regards
Klaus from Salzburg/Austria
Active Contributor
h.eger
Message 7 of 7 (600 Views)
09-04-2013 03:30 AM in reply to: k.schachinger
Hallo Klaus,
kannst du dich mal mit mir in Verbindung setzen.
cad@ae-eger.de
mfg
Hartmut
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
